Hello
I would like to show you something again after a long time.
I have built the 15cm sFH from Italeri ex Toxo. A nicely detailed model, easy to build. Except for the 2 part barrel of the howitzer, which caused some extra work. There were 5 crew members. Unfortunately they are with the early uniform. The painting only indicates 1943 onwards, so I decided to build the FH in transport position. As I was waiting for an 8 ton tractor I painted some figures in between.
1. the crew of the howitzer
2. russian scout troop Zvezda
3. german infantry Zvezda
