Hello, so I have a large decal I want to put on a sail of a ship. The sail, has some ridges for the rope lines that may make it tricky. The sail looks like this one. the sticker is about 2"x3"
I do not have much experience with decals except for my youth, and I remember even the small ones to be tricky.
I did buy some of those fluids that help float it, and "melt" them to the surface. (to make it look more melded to the surface)
So I see a few options to take.
1. Try it like normal sticker, and slide onto surface, over everything, allowing gaps between the ropes, and sail, then using the melter along the sail ropes to break it, and use a brush to get the edges to fill those gaps, (maybe use exacto to help cut it along the rope lines once set) then use the melter to seal it on there good.
Pros- this may work.
Cons- if I do not get proper placement on first go, it will be difficult to slide to new position due to ridges causing friction.
2. Cut the decal into strips, and cut out the gaps of the ropes and slide each section in individually.
Pros- no air gaps in sail
Cons- may tear he decal easier, and getting proper alignment may be tricky
3. Submerge the sail in a tray of water, then float the decal in the water above it, and lift it up to get proper placement.
Pros- more flexibility in placement
Cons- if it folds its done for, and the glue may all dissolve requiring more of the melter, which may smear the design.
Thank you for any tips
