After reading the question,of How to Cast a Figure,I decided that as a member of the Forum that I would do my utmost to answer it in a most correct and by far,not a complicated way of doing so.To cast a few figures it is not worth the money out- lay,however in my case I need about 300 of the Grenadiers already shown.So it is well worth my effort ,time and money to do so.
This is what you can buy for £150,in order to make Rubber Mould`s for casting Plaster or Plastic Resin( Not Metal! ) I did not buy this product.
As seen below,at under £6.00 for two,I decided to make my own Rubber Stuff up myself and save tons of money by buying this type 100% Silicon instead. The process of how to,I have already described. By doing so the money I saved paid for all my other stuff.
I have trolled the Internet and have bought high Quality stuff,to make Moulds a plenty. High Heat Resistance Rubber 1 kg kit`s as seen above at £20.00, which will be used in connection with Metal Casting. Also Lots of 100% Silicon for Mould Making which will be cast in a One to One Mix Plastic Resin. The cost came in including shipping cost`s around the £100 mark,however this is not to bad for Two Systems of casting Model Soldiers . I will have enough stuff to cast hundred`s of model`s,and make lot`s of Mould`s too.Plus what an education my Grand Children will have making their very own favourite Toy`s. More Metal I`ll need later,but what the heck it`s only money,a mean`s to an end. Lot`s of stuff on You Tube on Casting up Metal Mould`s,Making Mould`s both in Rubber and Silicon. I will also be making 28mm scale Mould`s too.All for my own personal use and not for sale,I have no intention to break Copyright Law ,a thing I happen to know a little about. On a closing note,there are people on You Tube melting down Coins to cast Moulds,I do not recommend anyone do this,because in Great Britain,10 year`s in Jail is not at all a nice future prospect to have. BB
