Filling gaps on metal
Posted by mickey mouse on 28 Nov 2022, 16:36
Hello all,
What is the best way to fill gaps and holes on metal models and figures?
mickey mouse  Netherlands
24 May 2012, 19:42
Posted by Bessiere on 28 Nov 2022, 17:03
It may not be the "best" way but I've used Vallejo plastic putty to fill gaps in metal figures with no issues. What I like is you can thin it down and apply several coats to fill in difficult spot. Hope that helps.
Posted by MABO on 28 Nov 2022, 21:24
I think you can use any putty you will find. I also worked with liquid green stuff from Games Workshop.
Posted by mickey mouse on 29 Nov 2022, 01:15
Thank you for your answer, gentleman! I shall give the putty a try, as i have it. The liquid green stuff i'll have to order.
24 May 2012, 19:42
Posted by Peter on 29 Nov 2022, 11:51
This is what they use for metal on cars. But it smells.
https://www.winparts.be/filters-vloeist ... oEALw_wcB#
Depends on the gaps you have to fill I think. ;-)
Posted by Michel on 29 Nov 2022, 13:21
Michel  Germany
02 Apr 2008, 08:21
Posted by Kekso on 02 Dec 2022, 10:55
CA glue and baking soda maybe?
Posted by mickey mouse on 08 Dec 2022, 00:04
Cheers, for the answers, gentleman.
24 May 2012, 19:42
Posted by Bessiere on 08 Dec 2022, 01:20
Using the Valejo plastic putty I just replaced the missing half of a sword sheath where the metal didn't get in to every part of the mold leaving a big gap. It remains semi-soft for days/weeks but can be shaped after that. I'm happy with how it came out cutting off the excess with a blade then following up with sanding sticks.
